Can't search for by parts of words in custom fields
Gerencia PS May 20, 2019
How do I search for parts of words in a determined custom field?
Example: i need to search for all the issues that contain "RMC" (like ACRMC and XYZ-RMC). In this case, the advanced search would be: "Custom Field" ~ "RMC", but no issues are showed.
When I change the criteria ("CustomField" ~ "-RMC"), it works for all the fields that start with RMC after the hyphen (it also shows the issues that contain "-RMD" even if the indexing language is in "Other").
How can I search for the issues that contain "RMC" in the middle of the word?
Zachary Miller May 20, 2019
Hi @Gerencia PS
With out of the box JQL we can sorta accomplish what you need here. In JQL you can use the CONTAINS operator "*" to specify a partial string.
  • IE
  • summary ~ "He*"
  • An issue would the summary "Hello World" would appear in the search
The limitation with this however is that this cannot search for string within a word
  • IE
  • summary ~ "ell*"
  • An issue with the summary "Hello World" would NOT appear in the search
If this limitation doesn't fit your current workflow I would recommend
https://marketplace.atlassian.com/apps/1216891/power-jql-extended-search-functions?hosting=server&tab=overview&_ga=2.46741029.369570024.1558354594-387361959.1527881499
This appears to have the necessary functionality to allow you to search within strings in JQL
