Hi.
I have an issue type called 'Spike', which is a like a research type issue.
It shares the same workflow with all other issue types in a Jira project.
Some of the other issue types have a workflow validation that checks if the Fix Version is populated before closing the issue.
The problem is that I don't want the Spike issue type to have the Fix Version as required.
I only want the Fix Version required for other issue types in the same project.
How can I fix this?
Do I need to create a separate workflow for the Spike issue? or is there a simpler way?
@Gil , You can achieve this by using boolean validator or script validator to exclude your project from validating for the close transition.
If you have JMWE add-on installed, use 'Fields Required Validator' where you can specify your project that needs to be excluded.
VJ
Sounds interesting, but not sure I understand.
I use automation for jira add-on, so I cannot add JMWE at this stage.
Can you please elaborate on the boolean validator?
Hi @Gil
I'm suggesting you to go with a seperate workflow..if you want same just copy it and take out that validation
That'll work
Kevin.
Unfortunately, I cannot create a new workflow for it.
There are many options, some of which were suggested above
There is more the one way to do it.
Thanks for the suggestions.
No.3 could work out well for me.
Thanks.
With scriptrunner you can make a validation depending on a condition.
