In your configuration is Epic Link a required field? Copy project, when it copies issues, deliberately does not copy the epic link. It creates new epics and links the issues to those.
I don't see how you can work round this other than (temporarily) removing the requirement to enter the epic link.
Hi Jamie,
The Epic Link is not set as a required field in field configuration.
image2017-2-3 18:52:32.png
Its a LOCKED field, no option to set it to Optional
Is there a workaround ?
By this, Copy project feature is unusable for such copying.
Any thoughts ?
