Cannot create an issue in Kanban Project
Charles Dominic Ventura October 10, 2019
Whenever I try to create a new issue, the project dropdown is not showing the Kanban project where I want to create the issue. The Kanban board is in a project of its own. I do have other boards, but they are next-gen boards. This issue I'm having with is with a classic kanban board.
Deepanshu Natani
Hi @Charles Dominic Ventura
This issue can occur if you do not have the permission "Create Issues" assigned in this particular project.
Please ask the project lead/ administrator to check if you have "Create Issues" permission assigned in this project in Jira.
Solved it. Thanks!
Like Deepanshu Natani likes this
Carlos Garcia Navarro
Hi Charles,
You may have checked this, but just in case: Did you check that your user has permissions to create issues in that project that doesn't show in the list?
Nevermind, Deepanshu was faster than me :-)
Hi Carlos. Solved it already. Thanks!
Like Carlos Garcia Navarro likes this
