Cannot find web resource module for: com.atlassian.jira.jira-issue-nav-plugin:backbone
Deleted user July 9, 2013
after the updgrade to Jira 6 we have the following errors in the logfile for various paths.
http-bio-8080-exec-56 WARN xxx 839x50871x1 1vwx0pz 53.48.15.29,127.0.0.1 /issues/ [atlassian.plugin.webresource.DefaultResourceDependencyResolver] Cannot find web resource module for: com.atlassian.jira.jira-issue-nav-plugin:backbone
Does anyone know how to resolve this? The Jira Webresource Boundle is activated and running.
Best Regards,
Adrian
Ryan Goodwin
July 10, 2013
Hi Adrian,
You're not running into any ERROR as these are warnings. However, they are annoying and fill up the logs ridiculously....
You're experiencing something like this bug:
https://jira.atlassian.com/browse/CONF-28107
I would recommend that you follow the workaround and set that logging class level to ERROR. That will get the warnings out of the logs.
Hope this helps!
jayasingh
Hi Ryan,
May i know why we are getting this warnings continuously in log. Before going to the workaround could you please tell the reason for these warnings.
Jayasingh
Deleted user March 26, 2014
Yes, Ryan. We'd like to understand the error as well.
Deleted user April 1, 2014
and what if setting the namespace to ERROR *doesn't* actually make them go away?
http://screencast.com/t/L24bzSOBy7AD
Deleted user July 23, 2014
I am getting a similar warning when I try to update plug-ins on our production Jira system. Here is the issue I am having.
  1. go to manage add-ons
  2. click to update a plug-in
  3. It seems to fill up the loading screen to about 70% and stops
  4. the logs show
    2014-07-24 12:00:52,781 http-bio-8080-exec-2 WARN anonymous 720x2622461x1 1jf76td 76.103.113.252,127.0.0.1 /s/d41d8cd98f00b204e9800998ecf8427e/en_US-9ws77h-1988229788/6265/209/2198011ec560d2bb621f91c47ec32f37/_/download/contextbatch/js/atl.admin,jira.global/batch.js [atlassian.plugin.webresource.DefaultResourceDependencyResolver] Cannot find web resource module for: com.atlassian.upm.atlassian-universal-plugin-manager-plugin:notificationsDataProvider
Rodrigo Donoso
July 13, 2014
I have the same warn using Jira 6.2.6 . Any idea how to fix this ?
