Dear all.
In our current Jira Data Center 9.12.15 with Script runner 8.36 we have a fully working script define as below :
import com.atlassian.jira.issue.IssueFieldConstants
import com.atlassian.jira.issue.attachment.FileSystemAttachmentDirectoryAccessor
import com.opensymphony.workflow.InvalidInputException
def log_edr = log.getLogger("com.edr.workflow.postfunction.GA.setAttachementsRequired_OnlyForCH")
def attachmentDirectoryAccessor = ComponentAccessor.getComponent(FileSystemAttachmentDirectoryAccessor)
def temporaryAttachmentDirectory = attachmentDirectoryAccessor.getTemporaryAttachmentDirectory()
Does anyone of you meet teh same behaviour and share some idea how to solve it ?
Does this class FileSystemAttachementDirectoryAccessor has been mode to an other lib ?
Thanks for your help
regards
Atlassian has made significant changes in Jira DAta Center 10.x, you can check the changelog here.
It is likely that the class FileSystemAttachmentDirectoryAccessor has been removed as part of these changes. See this thread, it may help your issue.
Hi Serge,
i have the same problem.
Do you find a solution?
@Tuncay Senturk _Snapbytes_ thank you for the links. Sadly in the first link atlassian didn't write something about FileSystemAttachmentDirectoryAccessor
