Cannot set Trusted Applications for Incoming Authentication when trying to connect to fisheye
Frank Farrell
September 11, 2014
gustavo_refosco
September 11, 2014
Hi Frank, Could you please clarify further what happens when you try to set it? Please also consider not using Trusted Applications. When creating the Application Link it is set by default as OAuth, and letting it as OAuth is the only way to have the Development Panel ( https://confluence.atlassian.com/display/JIRA/Viewing+the+Code+Development+Information+for+an+Issue ) working.
