Cant start JIRA after upgrade to JIRA 7
Azfar Masut
The following appears in catalina log  jiraXXXstderr.YYYY-MM-DD.log
16-Nov-2015 14:29:06.887 WARNING [main] org.apache.catalina.startup.Catalina.load Catalina.start using conf/server.xml: Error at (35, 68) : org.apache.catalina.core.JasperListener
16-Nov-2015 14:29:06.902 SEVERE [main] org.apache.tomcat.util.digester.Digester.startElement Begin event threw exception
 java.lang.ClassNotFoundException: org.apache.catalina.core.JasperListener
    at java.net.URLClassLoader.findClass(URLClassLoader.java:381)
    at java.lang.ClassLoader.loadClass(ClassLoader.java:424)
    at java.lang.ClassLoader.loadClass(ClassLoader.java:357)
    at org.apache.tomcat.util.digester.ObjectCreateRule.begin(ObjectCreateRule.java:116)
    at org.apache.tomcat.util.digester.Digester.startElement(Digester.java:1184)
    at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.startElement(AbstractSAXParser.java:509)
    at com.sun.org.apache.xerces.internal.parsers.AbstractXMLDocumentParser.emptyElement(AbstractXMLDocumentParser.java:182)
    at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanStartElement(XMLDocumentFragmentScannerImpl.java:1343)
    at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl$FragmentContentDriver.next(XMLDocumentFragmentScannerImpl.java:2786)
    at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next(XMLDocumentScannerImpl.java:606)
    at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(XMLDocumentFragmentScannerImpl.java:510)
    at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:848)
    at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:777)
    at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(XMLParser.java:141)
    at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(AbstractSAXParser.java:1213)
    at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(SAXParserImpl.java:649)
    at org.apache.tomcat.util.digester.Digester.parse(Digester.java:1457)
    at org.apache.catalina.startup.Catalina.load(Catalina.java:551)
    at org.apache.catalina.startup.Catalina.start(Catalina.java:613)
    at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
    at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
    at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
    at java.lang.reflect.Method.invoke(Method.java:497)
    at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:351)
    at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:485)
Azfar Masut
If the server.xml was copied over from the previous older installation, just update the file with following on the listener section
<Server port="8005" shutdown="SHUTDOWN">
 <Listener className="org.apache.catalina.startup.VersionLoggerListener" />
    <!-- Security listener. Documentation at /docs/config/listeners.html
    <Listener className="org.apache.catalina.security.SecurityListener" />
    <!--APR library loader. Documentation at /docs/apr.html -->
    <Listener className="org.apache.catalina.core.AprLifecycleListener" SSLEngine="on"/>
    <!--Initialize Jasper prior to webapps are loaded. Documentation at /docs/jasper-howto.html -->
    <!-- Prevent memory leaks due to use of particular java/javax APIs-->
    <Listener className="org.apache.catalina.core.JreMemoryLeakPreventionListener" />
    <Listener className="org.apache.catalina.mbeans.GlobalResourcesLifecycleListener" />
    <Listener className="org.apache.catalina.core.ThreadLocalLeakPreventionListener" />
    <!-- Global JNDI resources
         Documentation at /docs/jndi-resources-howto.html
    <!-- A "Service" is a collection of one or more "Connectors" that share
        a single "Container" Note:  A "Service" is not itself a "Container",
        so you may not define subcomponents such as "Valves" at this level.
        Documentation at /docs/config/service.html
