Cascade Field required
arno
Hi all
   I created a new cascade field and set it as required. When I select the first option, I can create an issue even if the second option is empty. How can I set the second option not to be empty so that the user can create an issue
CHINNAMUTHEVISAI.SATYANARAYANASHARMA
Hi Arno,
we can do this through JMWE Plugin.
select the workflow and on initial transition click on condition add field required validator JMWE and in condition add this after selecting issue fields
issue.customfield_24469 && issue.customfield_24469.child.value
I got this now.
Marco Brundel
April 19, 2023
Hi @arno ,
Have also a look on this question or this question.
regards, Marco
Fabio Racobaldo _Catworkx_
Hi @arno ,
there is a specific ticket for that request https://jira.atlassian.com/browse/JRASERVER-33123
Currently there is a workaround using an external app :
Workaround
Use the Suite Utilities for JIRA plugin and the "Field Required" workflow validator
  • You would add this to the Create Transition and also make the field required
  • You need to make the field required so that it will show the red asterisk indicating that it is required
Hope this helps,
Fabio
Hi Fabio,
If we use JSU plugin and field required Validator , then it will take only Parent field right ? it wont consider if we have a value in second option or not right ?
Hey @CHINNAMUTHEVISAI.SATYANARAYANASHARMA , if you use Field Required validator provided by JSU, both options will be mandatory
With JSU , i'm not able to achieve it , but from JMWE i got this one as expected.
SERVER
