Dear Community,
I'm looking to create the issue from Python script with the below coding. Our's JIRA is on AWS.
Then script is returning the error message as below. Does any one experienced access JIRA from Python script?
{"errorMessages":["Can not deserialize instance of com.atlassian.jira.rest.v2.issue.IssueUpdateBean out of START_ARRAY token\n at [Source: org.apache.catalina.connector.CoyoteInputStream@7edec606; line: 1, column: 1]"]}
The coding is here.
# Script to create the JIRA Story based on the Issue Key
import requests
import json
from wsgiref import headers
from pip._internal.network import auth
import JIRAonAWSRestAPI
def main():
url="https://jira.companyname.com/rest/api/2/issue"
username="ouruser"
password="ourpassword"
myheaders= {'Content-type':"application/json" , 'Accept':"application/json"}
payload=[
"fields": {
"summary": "TEST JIRA Issue in for JIRA on AWS ",
"issuetype": {
"id": "10001"
"project": {
"key": "ITD"
"assignee": {
"name": "ourusername"
"components": [
"name": "SALES"
"customfield_10302": "2021-07-28",
"customfield_10301": 16 ,
"customfield_10303": {
"id": "10666"
response = requests.post(url, data=json.dumps(payload), headers= myheaders, auth=(username, password))
print(response.text)
if(__name__ == "__main__"):
main()
Praveen
I got the correct info from the existing question in the community that the standalone documentation alone from atlassian for python script
https://atlassian-python-api.readthedocs.io/index.html . I will refer that.
Praveen
