I have added the following JVM parameter "-Dfile.encoding=utf-8" to the setenv.bat file and have restarted Jira, amd have followed all documents online how to update the system encoding but it is still Cp1252 and I can't work out why this isn't changing. Please may someone help!
Hi Callum,
You can try set "-Dfile.encoding=utf-8 -Dsun.jnu.encoding=UTF-8" JVM arguments .
Mehmet Sirin
Thank you for your reply, this worked for me, thank you!
thanks mehmet.
can we apply this manipulation on a production environment where several projects are in use without risk?
