Change default columns for Issue view
Naim Karabag
August 3, 2021
Hi guys,
is it possible to change the default columns within the standard issue view (s. picture)?
I know you can create filter-views but it would be more comfortable to change the default view.
Thanks in forward!
Federico Scala
I have the same question since I still didn't find a solution.
The options in the "Columns" button apply only to the advanced search section or to saved filters.
Is there a way to change the columns in the first standard view? It's so weird that no customization seems to be available.
Alexander Pappert
August 4, 2021
in the right menu, where you add/delete fields, there is a default view
but this is only your default
if you wan so share the filter with other users, you sould create a view for every shared filter
https://confluence.atlassian.com/adminjiraserver/configuring-the-default-issue-navigator-938847005.html
