Change the workflow of an issue using jira-python.
Venkat
July 3, 2019
I am trying to change the workflow of an issue in jira programmatically. Is there anyway to change the workflow of an issue using jira-python?
Post a new question
Warren
July 4, 2019
Hi @Venkat
You would use this API call
/rest/api/3/issue/key/transitions?expand=transitions.fields&transitionId=141
where key is the Jira key (e.g. ABC-123) and 141 needs to be the transitionId of your instance for the status you're changing to.
You would POST this with a JSON that looks something like
"update": {},
"transition": {
"id": "141"
If you need to include resolving the ticket as well, then the JSON would be
"update": {},
"transition": {
"id": "241"
"fields": {
"resolution": {
"name": "Done"
again replacing 241 with your transitionId
Nir Haimov
Venkat
July 4, 2019
We are using python script instead of API. Below is my python code.
options = {'server':'https://xxxx.atlassian.net'}
jira = JIRA(options,basic_auth=('xxx@xxxxx.com', 'xxxxxxx'))
issues = jira.search_issues('project=xxx')
print(issues)issue = jira.issue('xxx-32')
jira.transition_issue(issue, transition = 'In BB')
issue.update(summary= 'new summary', description= 'A new summary was added', issuetype ={'name': 'Change Release'})
By using issue.update I can update the issue type. But I cant update the workflow. Both the issues are in same project. How can update the workflow using python code instead API
Nic Brough -Adaptavist-
July 6, 2019
You say "We are using python script instead of API." - that is nonsense.  There are only two ways to do what you are trying to do - in the UI or over the REST API.
So what you mean is "We are using a python script to call the API".
You will need to amend the python script so that it sends valid JSON to the API.  I don't know python in that area, but Warren and Nir have given you what you need to build to send over, and I know python can make REST calls.
