×I need to determine if I can change a Project name and what ramifications it will have. We have BitBucket integrated with the projects to link to the source code and I believe those are in the same name as the project. If I change the name will it try to change the project # too?
Hi @Melanie Frasier ,
Changing the Project name in Jira should not have an issue. The project key is the main thing to make sure to leave unchanged. You may have some items in your bitbucket that is tied to issue keys for Jira updates
Ben
