Chrome 45.2.2454.18+ breaks JIRA 6.3.15 with Smart Attachement plug installed
PulseI September 2, 2015
This is just a FYI
When running Chrome (45.2.2454.18 or higher) with JIRA 6.3.15 and have the "Smart Attachements" plugin installed all JIRA issues pages no longer render correctly.
Currently waiting on Vendor for fix.
Nic Brough -Adaptavist-
September 2, 2015
I think you need to raise this with the add-on vendor or Google - they've got something in their code that breaks Chrome, or Chrome has a bug that is triggered by their code.
With Smart Attachments Plugin enabled
Vadim Rutkevich
September 16, 2015
This issue has been resolved. I believe you have contacted us via HelpDesk. Sorry for the temporary inconveniences.
With Plugin Disabled - Looks normal
