Clone Zephyr for Test Case across multiple project using JIRA REST API or ZAPI
Lalit Verma July 17, 2014
Hi
I have some TEST in a project created using the Zephyr for JIRA plugin. Now as I clone the project the TEST are cloned but the Test Step or execution details are not cloned.
For accessing the TEST I am using ZAPI for Zephyr for JIRA. I wanted to know that is there any way through which I can clone TEST across two different project using ZAPI or JIRA REST API.
I have undergone through the ZAPI documentation but there is REST URI for bulk cone of the TEST.
Is it possible or not ?
Swapna Kumar Vemula _Zephyr_
December 18, 2014
Hello Lalit,
This questions was answered for you from our ticketing system. Please find the same here.
There is no direct way to clone a TEST from one project to another project through ZAPI or Zephyr for JIRA.
However, you can import the same test case to a different project using the Zephyr importer utility.
Once you export the test cases to a excel sheet, you can use the importer to get the test cases into a different project. You can download the importer here at https://bitbucket.org/zfjdeveloper/zfj-importer
You can also refer:
http://www.youtube.com/watch?v=y5pCg5lSrBk
Kind Regards,
Swapna Kumar Vemula
John Paz
September 26, 2014
Bump
