×We currently want to archive issues as read-only subtasks before reopening them. I planned to use the Create on Transition for that, but as the issue has >50 custom fields (which are subject to change) this seems not useable.
@Bob Swift [Bob Swift Atlassian Add-ons] Is there a possibility to give wildcards in the "Copy parent issue custom fields" parameter?
Any other suggestions are welcome!
As a last resort I would write a script-runner script for it...
Thanks in advance
Thomas
I found https://marketplace.atlassian.com/plugins/net.customware.jira.utils.customware-jira-utilities and resolved it with the "Copy Issue Function"
Other possibility is using Script Runner. You don't need to write a script because already has a postfunction called clone issue and links (you can skip the link part).
No, its not currently possible. Are you looking to copy all or perhaps a regex selection? Or just a simple end generic (cust*)?
CSOT-248 was created to cover this requirement.
I want to copy all fields, a cust* would do... (In the end I want a clone with a subtask as target)
