×when i test my plusgin compatibility with the 5.2 version of jira via the jira update check feature
it report that this plugin is incompatible.
is it true or it is just not tested?
Yes the plugin is still not fully compatible with JIRA 5.2 as mentioned in the plugin page https://marketplace.atlassian.com/plugins/org.swift.jira.clone-plus Looking through at the page, the plugin developer is aware of this issue and currently tracking the issue on https://bobswift.atlassian.net/browse/JCPP-90 I will suggest you contact the plugin developer for updates
Correct. It is compatible except for one customization option that is not working correctly and that is documented in the issue. If you are not using that specific customization feature, then you are good to upgrade.
