If i use the JSON fix, I get the error: data was not an object (parent). The parent was a "bug" issue, so this should not be a problem.
Cloning sub tasks seems to be in the backlog since 2017, is there any update on when this will be released?
The workarounds posted doesn't seem to work anymore and I'm looking for a solution to clone an issue along with sub tasks from one project to another...
Hi, I meant as mentioned here: https://community.atlassian.com/t5/Marketplace-Apps-Integrations/How-clone-a-task-and-its-subtasks/qaq-p/605089
The goal was to turn sub-tasks into sub-tasks clones in a new project.
The workaround we use now is to stay away from sub-tasks and only use issues/stories.
Hi @Bart Jacobs,
It looks like a lot of users manage to get it to work with the Automation feature; for example - this thread.
That being said, would it be possible to provide a screenshot of your configuration and also the error that you are seeing?
Moga
Hi @Bart Jacobs ,
Please share with us what is the JSON fix? What do you mean by:
And also what is the workaround that you have tried?
Moga
