When I clone a task, I can check to clone links or sprints.
But when I clone a sub-task, these options are not available, why?
How can I set get the options available?
Thanks for feedback
Vincent
Hi Vincent, how are you?
Actually, you can check the option to Clone links when cloning a sub-task. Regarding the Sprint option, that is not possible because Sprints are related to tasks so subtasks only inherent this field from its parent.
JOÃO NUNES
Jira Support Team
