×Is there a way to clone an Existing Project in Jira Software?
I create my existing project as template to reuse it. but when I create Project there's no use template button.
@Mar Angelo L. Tareno I am assuming that you mean by cloning it you would like to have it copy all of the work items (issues) you created in the project? If that is the case you would need to:
If you just want to use the project settings you can create a new company managed project following these steps:
If you want to use the settings and issues then you can create the project first based on the settings of the other project and then do a CSV import of the work items (issues)
Yes – you can turn an existing Jira project into a reusable template with our app Deep Clone for Jira. The app’s Project Clone feature lets you duplicate a whole project (or just the framework) in a few clicks, including issues, versions, components and configuration schemes.
Need the board or a team-managed project?
Enable the optional Advanced Project Clone once (Apps › Manage your apps › Advanced Project Clone) and Deep Clone will also:
If you're a Jira admin, you can share settings with an existing project. During the creation of a company-managed project, there should be an option to "share settings with an existing project" available (again, if you’re a Jira admin 😊 ).
The new project will share the same configurations as the template project, including issue types, workflows, screens, fields, permission schemes, but it won't copy existing issues, boards, project-specific filters, or automation rules.
I’m also including a link to a Marketplace add-on, Issue Templates for Jira (developed by the company I work for). This app lets you create templates that you can reuse across multiple projects.
For example, if your "template project" includes standard tasks, sub-tasks, epics, etc., you can save them as templates and recreate the entire issue structure in a new project.
I've recently published an article on the Atlassian Community on how to clone a project in Jira, it might help you :)
