I have a plan in Jira with Versions as milestones. I have capabilities, epics, stories and tasks. The capabilities are parents of Epics. When an Epic status is set to closed in Jira then the epic disappears from the plan but all of the stories and tasks under the stories become orphans showing up at the bottom of the plan with no parent. If I set the Epic back to testing everything is fine but I am not able to show the correct progress of the plan. Any Ideas?
Hi @Jann Thomas
Give it a try with
section: To set how long to display completed issues:
https://confluence.atlassian.com/advancedroadmapscloud/issue-sources-998651043.html
or this
Troubleshooting: I don't see closed issues under my plan
https://confluence.atlassian.com/advancedroadmapscloud/configuring-the-scope-view-998651442.html
Neither of those are working. I have closed issues for 180 days. The closed stories are showing as orphans but the closed epics are not showing.
