I have request from user where they want to add a drop with list of three color Red Blue and Amber. F.g for priority field comes up with different set of color. we want some thing in similar way.
Hi There!
You can try this plugin: https://marketplace.atlassian.com/apps/1219385/rainbow-field?hosting=server&tab=overview
We also much apprecated any feature requests!
I have attached the screenshot of what i am getting at the moment however my requirement is still slighlty different. I need something like
color icon - field text
Red color iconIn UAT Status
Green Color iconIn Process Status
Attaching screen shot in ms paint
You can change colors via post functions and it will be correspond to status.
Actually its not the status. I just wrote it to explain it you. Its just the custom field with color. If you at the very first screen shot of priority field. I need some thing like that
Red color icon - UAT
Green color- Deployed
Hi!
I am developer of plugins: https://marketplace.atlassian.com/plugins/ru.andreymarkelov.atlas.plugins.colorfieldsandhttps://marketplace.atlassian.com/plugins/ru.mail.jira.plugins.color-custom-field-plugin
I can help with it. What do you want to do?
Hi Andrew,
I have added plugin and was able to locate a new custom filed "Select color custom filed" I created a filed color with that field type however i'm not getting the place where i could specify the colors.
Go to custom field page. Locate recently create field. Click "Configure". On the opened page click "Edit Options". Add colors to options using html colors: red, green, etc and RBG #ff00aa. https://bytebucket.org/amarkelov/andreymarkelov-atlas-plugins-color-custom-fields/wiki/pic6.png
Please, try
you can try with following plugin
or try with following plugin
https://marketplace.atlassian.com/plugins/org.hakanai.jira.plugins.jirastatuscolor
i have installed the plugin from the first location and it looks it got installed howeve I'm not sure how to use it. Its not listed in my custom field like other fields.
