Column configuration in Issue Navigator resets after clicking on a column header
Vedran Grudenic October 2, 2014
I am trying to configure the Issue Navigator to show certain custom fields for a list of issues according to the documentation. Selected columns show up properly after I click Done in the Columns config. dialog, but if I click on any column header to change sort order, or try to refresh the page, added columns disappear and it switches to default.
I also don't see any difference when using the System tab inside the Columns config. dialog, and what's even stranger, I have noticed that the System tab can be clicked by non-admin users also.
Is there a way to make this configuration permanent? I am using JIRA v6.2.5#6262.
Ollie Guan
For example, project-specific custom fields will be shown only if the filter has been restricted to that project only. Issue type custom fields will only appear if the filter has been restricted to that issue type.
Ollie Guan
Some custom fields is to match the project or issuetype, you need to indicate the specific information in the query conditions
for example:task has custom fields <activity>
Then:
issuetype = task and project = XXXX
Vedran Grudenic October 17, 2014
But isn't this a bug? What's the point of making the columns appear as sortable, if they disappear if you try to sort?
Ollie Guan
i think you can try this plugin
Column Order Gadget Plugin
https://marketplace.atlassian.com/plugins/at.celix.jira.plugins.column-order
