Hello, I have a requirement: when (customfieldA = "A" or "B") and (Components is "X" or "Y"), then set Assignee to "userZ". How do I write the code in the Universal Post Function Expression? I tried everything with brackets and quotes, but the combination of a custom field and Components doesn't seem to work. Please do not answer with Scriptrunner coding, because I don't know how to use and do that. Thank you for your help!
