Hi there,
So on a couple of the transitions I have added a comment required validator in the work flow. However, when working on a bug, even after I have added a comment, the validator error appears when I try to update the workflow. As far as i can tell I am doing everything necessary, so any help much appreciated!
How's your comment validator settings for the transition are set? You can paste your settings here and we can analayze from there!
Could you let us know what the error message says?
