When I use Comment issue post function, I add log events for debugging. However, I've noticed INFO events don't work for me. Only when I use log.warn(...) events, they show up in atlassian-jira.log.
Even when I've added jmwe.plugins.functions.CommentIssueFunction package to log4j.properties, it's still a no-show.
When should I do to add there INFO events to my log?
Could something like this work (as it does in Script Runner):
import org.apache.log4j.Category
def Category log = Category.getInstance("jmwe.plugins.functions.CommentIssueFunction");
log.setLevel(org.apache.log4j.Level.INFO);
The right package to add to log4j.properties (or in the Logging settings of JIRA admin) is "com.innovalog.groovy" if you want to get the results of log.info() calls in your Groovy script.
Hi David,
Thanks for your response. I've tried both adding
log4j.logger.com.innovalog.groovy = INFO, console, filelog log4j.additivity.com.innovalog.groovy = false
To log4j.properties as well as adding this package to the Logging settings in JIRA's UI. None showed any log event.
Is there something else that could be done?
My bad. The correct package (class, really) is: com.innovalog.jmwe.plugins.functions.CommentIssueFunction
Thanks David. com.innovalog.jmwe.plugins.functions.CommentIssueFunction worked
