Component/s section is missing while raising JIRA Ticket
sriram vasudevan June 4, 2013
Hi Team ,
While creating a JIRA ticket , i can't see the component/s section. I tried to see inside the Configure Field-> All I can view only two section checked like 1.Summary and 2.Description rest all are invisible. How to fix this? please help thanks in advance !!
*Note: But i can see the component/s field if i change the project.
sriram vasudevan June 10, 2013
Thanks Bhushan & CK for the prompt solutions.
Raju KC
June 4, 2013
Those fields are missing either in the screen or hide in field configuration. Please see the screen or field configuration.
Ck Thanks for your promt reply,
Yes those fields are missing in the screen as well as hidden in the Field Configuration winzard.. What should be done ?
sriram
Bhushan Nagaraj
June 4, 2013
Read the answer. You need to add the fields to the screen, and show the fields in the field configuration.
Bhushan Nagaraj
June 4, 2013
Hi Sriram,
You need to check the following:
1. Field Configuration: Check your project's field configuration and make sure the Components field is not hidden
2. Screen: Check the screen being used for "Create Issue" by your project and add "Components" field if it is missing
Read more about screen schemes here
https://confluence.atlassian.com/display/JIRA/Associating+a+Screen+with+an+Issue+Operation
Read more about field configurations here
https://confluence.atlassian.com/display/JIRA/Specifying+Field+Behaviour
Cheers
Bhushan
Bhushan Nagaraj
June 4, 2013
First "Show" the field in your project's field configuration.
https://confluence.atlassian.com/display/JIRA/Specifying+Field+Behaviour#SpecifyingFieldBehaviour-Hidingorshowingafield
Then you will be able to add it to the screen.
https://confluence.atlassian.com/display/JIRA/Defining+a+Screen#DefiningaScreen-Configuringascreen'stabsandfields
2. I am unable to add the components in the create Issue screen as well.
Are you unable to see the Components field here?
Thanks hushan for reply,
As already mentioned in 1. Field Configuration - components field is hidden 2. I am unable to add the components in the create Issue screen as well.
thanks
sriram
