×I have two text fields. The first will appear at the screen of the transition and will be used to receive a temporary information. At the post-function transition I need to concat the information of the first field with the second field, but my second field will already have informations, then I can't just overwrite this.
How can I concat these 2 fields?
Update issues should be able to do this. You can use Substitution variables to set a custom field to a text string formed from text and any number of custom field values.
