Conditional Custom Fields
Patti
March 23, 2022
I created some custom screens with lots of custom fields but I can't figure out how to,
1 - Set up conditional questions - so for example, if I have a drop-down menu question with options YES/NO, if i select YES I want an additional question to come up in my screen, but if I select NO, I want the question to remain hidden and not made visible to the user filling out the form/screen.
2 - My screens have different tabs. Is there a way to show/hide tabs depending on where my issue is at within a workflow?
I'd prefer to do this with out of the box solutions, but if i need to use script runner I do have that available as well. I do not have a development background so the more info you can provide if it has to be script runner the better.
Thank you much!
Noemi Flores
@patti did you ever figure this out?
