I recently installed the Conditions Validator plugin (version 2.0.2) on our JIRA instance (version 5.1.4). Since then our users have been experiencing a javascript error in IE8 whenever they transition an issue.
The spinning wheel stays on and a javascript error flag shows up on the bottom of the page. The user has to refresh the page to continue working. By refreshing the page, we can see the transition went through.
So this issue is not blocking but it is definitely annoying for our user experience.
When we disable the conditions validator plugin, this problem does not occur anymore.
Hi Bertrand,
Looks like there is some problem with the javascript that is in the Conditions Validator plugin that is erroring out. You need to contact the plugin provider to inform them about the same.
I researched a bit and I found a few articles that have some suggestions on fixing the problem :
I hope this helps!
Hi Bertrand,
Can You confirm this bug in newest version (2.0.7) ?
Hi Bertrand,
From the screenshot, it seems that is a plugins faulty. But it may too soon to tell.
Can you check on the following:-
Do this affect to the other browser as well?
Cheers
KM
