I'm using Jira Work Management
And currently trying to add a Due Date fields in Jira Work Management, but I tried to click on configure there is nothing I can do to add and show the due date.
It's such a basic thing to show due date. Where can I edit the fields ya?
I cannot find the edit function in the Screen. (The pencil button) does this mean I cannot edit the field? And it has to be the admin?
Hi Vina - Welcome to the Atlassian Community!
It is probably that the Due Date field is not on the Edit Screen or Edit/View screen for the project. If you add it there, you will then see the field.
Go to Project Settings then click on Screens.
Then click on the Edit/View screen and add the Due Date at the bottom of the screen.
