Configure Workflow Transition Post-Function to Fire Custom Event
Donell Peters June 30, 2016
I have been following the instructions on this page, but at the end can't figure out the steps in the Post Function Transition.  https://confluence.atlassian.com/display/JIRA050/Adding+a+Custom+Event
  1. Update the post-function to fire the custom event.
I do not see a Custom Event Post Function listed on the screen.
Jobin Kuruvilla [Adaptavist]
June 30, 2016
Most transitions, by default, has a post function to fire a generic event. Edit it and change the event to your custom event. You can only fire one event.
Narasimha murthy
Hi Jobin,
do we only have to fire the Generic/Custom events? all other system events will work without adding fire post function in the workflow transition?
Petar Petrov (Appfire)
June 30, 2016
Add the "Fire Event" post-function and select the Custom Event which was created in the previous steps.
I don't see a Fire Event Post-Function option on this screen.
image2016-6-30 15:31:29.png
thekngmkr2015 October 20, 2017
Script runner gives this add on
Jenn Sherman
After you select post-function, I see a "generic event" action.  When I edit that line, I can see the list of actions including my custom event.  This is without script runner.
Script runner gives this post function option
