I want to configure one incoming email per project in Jira. For example Proj1@acme.atlassian.net, Proj2@acme.atlassian.net and so on.
System - Incoming Mail - Default Cloud Mail Server is set to jira@acme.atlassian.net which works for one project however
When I go into project Settings -> Summary -> Notifications -> Email
Update email to Proj1@acme.atlassian.net instead of jira@ac... The email bounces.
Can you please advise.
Hi @Saadan Rehman,
Please note that each incoming mail handler needs a dedicated email address. You have to navigate to https://acme.atlassian.net/secure/admin/IncomingMailServers.jspa and under POP / IMAP Mail Servers and add a new POP / IMAP Mail Server.
Please refer to the below screenshot
You can use them for defining a new email handler (ideally, one per POP/IMAP mail server)
Reference:
Ravi Varma
