I want to configure our JIRA server (Windows Server 2012 R2) for HTTPS following the documentation at https://confluence.atlassian.com/jira064/running-jira-over-ssl-or-https-720411727.html and I am not able to success
We have a .p12 key pair file and a set of signed certificate files from a CA.
I performed the following steps:
All of the above steps were without errors.
But when I try to restart the Windows Service "Atlassian JIRA" it failed.
When I configure it back to HTTP via config.bat the service ist starting.
I don't know what is going wrong. In the various log files I can not find specivic errors.
Hello Mihai,
in the meantime I could solve the problem.
The reason im my case was the graphical JIRA configuration tool for the web server (config.bat).
Every time I configured SSL/HTTPS over this tool, the windows service "Atlassian JIRA" could no longer be started.
When I edited the server.xml file manually and made the corresponding entries for HTTPS, the service started without problems and the JIRA site was accessible via HTTPS.
Regards
Christian
Hello Christian,
Check the logs you might find some useful information there.
