×Hi
On the plan mode of scrum board (jira-agile) , i want to configure a few more columns. I want to use those fields to determine the rank of my issues.
At the moment plan mode only displays issue type and priority.
How can i add another attribute to it?
Rahul
Hi Rahul,
This is currently not possible through a simple configuration.
You could try to change the templates in the JIRA Agile plugin jar file, but I wouldn't recommend it.
If you want to rank your issues based on certain other fields you can also do this in the filter your board is based on. Simply replace the ORDER BY Rank desc with ORDER BY <your fields> desc.
Best regards,
Peter
thanks Peter....
