Confluence Insert ‘JIRA Issues Calendar’ Macro Error
Jiannan Tang
I use Confluece External Gadgets function.
And I had added some Gadgets, But only issuescalendar-gadget fail.
The Error show on page is
An internal server error occurred when requesting resource .
Danielle Zhu
June 5, 2013
Please make sure the Calendar plugin is installed in JIRA, and application linking is configured between JIRA and Confluence.
Jiannan Tang
Thanks Danielle
JIRA had installed the plugin, and show perfet.
The application link had been configed, And other JIRA plugin show good in confluence.
Only Calendar bloken.
Jiannan Tang
Hi Hanis:
The gadget in look good in JIRA dashboard.
Jiannan Tang
Hi Hanis:
I confirm the added gadget is JIRA Calendar gadet.
the Gadget Specification URL is:
http://jirabaseurl/rest/gadgets/1.0/g/com.atlassian.jira.ext.calendar:issuescalendar-gadget/templates/plugins/jira/portlets/calendar/gadget/calendar-gadget.xml
hsuhailah
June 6, 2013
The link looks good. Can you successfully view the gadget in JIRA dashboard?
hsuhailah
June 5, 2013
Can I get a confirmation that you were referring to JIRA Calendar gagdet?
Jiannan Tang
My jira version is 5.2.8
Confluence is :5.0.2
