I use Confluece External Gadgets function.
And I had added some Gadgets, But only issuescalendar-gadget fail.
The Error show on page is
An internal server error occurred when requesting resource .
Please make sure the Calendar plugin is installed in JIRA, and application linking is configured between JIRA and Confluence.
Thanks Danielle
JIRA had installed the plugin, and show perfet.
The application link had been configed, And other JIRA plugin show good in confluence.
Only Calendar bloken.
Hi Hanis:
The gadget in look good in JIRA dashboard.
Hi Hanis:
I confirm the added gadget is JIRA Calendar gadet.
the Gadget Specification URL is:
http://jirabaseurl/rest/gadgets/1.0/g/com.atlassian.jira.ext.calendar:issuescalendar-gadget/templates/plugins/jira/portlets/calendar/gadget/calendar-gadget.xml
The link looks good. Can you successfully view the gadget in JIRA dashboard?
Can I get a confirmation that you were referring to JIRA Calendar gagdet?
