Confluence - Jira Issue Macro malfunction
Jinrui Mai December 17, 2012
The steps to reproduce the issues:
1.Browse to Confluence page edit page.
2.Click insert macros - choose Jira Issues macro.
3.Input the URL field with value copied from Views>XML>Copy link address(by right click) in issues navigator page.
4.Click "refresh" on the right side.
There will be an error displayed like that:
Unable to generate JSON output<br/>class java.io.IOException
RianA
December 17, 2012
Hi Jinrui, please check the URL of JIRA Issues macro whether it's XML View or just the normal issue navigator view. This issue has been raised as knowledge base article before.
* https://confluence.atlassian.com/display/CONFKB/java.io.IOException+on+JIRA+Issues+Macro
Jinrui Mai December 18, 2012
I am sorry for my unclear expression,please have a look again ,it's XML View.And I found that it may be related to the Application Link which should be set between JIRA and Confluence.But when I set the link to confluence in Jira server,it said that the confluence server is not able to connect to the "Reciprocal link URL" which is the URL of Jira. The error shows like :
The Remote application is not able to connect to 'Sierra Atlantic Collaborate'(JIRA) by using the URL 'https://<EXAMPLE>/jira'.
