×Hi,
I read multiple community Q&A's and multiple tutorials to get my Jira and Confluence installation working on a single server. I use lets encrypt SSL installed with certbot auto.
Confluence: - suba.domain.com, HTTP Application port 8080, Tomcat HTTP port 8091 and synchrony port 9095.
Jira: - subb.domain.com, HTTP port 80, Tomcat HTTP port 8090.
I ended up with Jira working on HTTPS on subb.domain.com but I can't manage to get confluence working. It works with HTTP. It won't work over https. I got the following configuration.
- Ubuntu 18.04 LTS
- Confluence 6.12
- Jira 7.12
My apache confg is:
# CONFLUENCE
<VirtualHost *:443>
ServerName suba.domain.com
ProxyRequests Off
ProxyVia Off
ProxyPreserveHost On
<Proxy *>
Require all granted
</Proxy>
RemoteIPHeader X-Forwarded-For
RemoteIPTrustedProxy 127.0.0.1
RewriteEngine on
RewriteCond %{REQUEST_URI} !^/synchrony
RewriteRule ^/(.*) http://suba.domain.com:8091/$1 [P]
ProxyPass /synchrony http://127.0.0.01:8091/synchrony
<Location /synchrony>
Require all granted
RewriteEngine on
RewriteCond %{HTTP:UPGRADE} ^WebSocket$ [NC]
RewriteCond %{HTTP:CONNECTION} Upgrade$ [NC]
RewriteRule .* ws://127.0.0.1:8095%{REQUEST_URI} [P]
</Location>
ProxyPass / http://127.0.0.1:8091/
ProxyPassReverse / https://127.0.0.1:8091/
<Location />
Require all granted
</Location>
SSLCertificateFile /etc/letsencrypt/live/suba.domain.com/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/suba.domain.com/privkey.pem
Include /etc/letsencrypt/options-ssl-apache.conf
</VirtualHost>
<VirtualHost *:80>
Redirect Permanent / https://suba.domain.com
RewriteEngine on
RewriteCond %{SERVER_NAME} =suba.domain.com
RewriteRule ^ https://%{SERVER_NAME}%{REQUEST_URI} [END,NE,R=permanent]
</VirtualHost>
# Jira
<VirtualHost *:443>
ServerName subb.domain.com
ProxyRequests Off
ProxyVia Off
<Proxy *>
Require all granted
</Proxy>
RewriteEngine On
ProxyPass / http://127.0.0.1:8090/
ProxyPassReverse / http://127.0.0.1:8090/
SSLCertificateFile /etc/letsencrypt/live/subb.domain.com/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/subb.domain.com/privkey.pem
</VirtualHost>
<VirtualHost *:80>
Redirect Permanent / https://subb.domain.com
RewriteEngine on
RewriteCond %{SERVER_NAME} =subb.domain.com
</VirtualHost>
and for server.xml
confluence:
<?xml version='1.0' encoding='utf-8'?>
<Server port="8000" shutdown="SHUTDOWN" debug="0">
<Service name="Tomcat-Standalone">
<Connector className="org.apache.coyote.tomcat4.CoyoteConnector"
port="8091" protocol="HTTP/1.1"
minProcessors="5"
maxProcessors="75"
enableLookups="false"
debug="0"
useURIValidationHack="false"
URIEncoding="UTF-8"
useBodyEncodingForURI="true"
compression="off"
compressableMimeType="text/html,text/xml,text/plain,text/css,application/json,application/javascript,application/x-$
proxyName="suba.domain.com"
proxyPort="443"
maxHttpHeaderSize="8192"
maxThreads="150"
minSpareThreads="25"
maxSpareThreads="75"
disableUploadTimeout="true"
acceptCount="100"
secure="true"
scheme="https"/>
<Engine name="Standalone" defaultHost="127.0.0.1" debug="0">
<Host name="127.0.0.1" debug="0" appBase="webapps" unpackWARs="true" autoDeploy="true">
<Context path="" docBase="../confluence" debug="0" reloadable="false" useHttpOnly="true">
<Manager pathname="" />
</Context>
</Host>
</Engine>
</Service>
</Server>
and for jira server.xml
<?xml version="1.0" encoding="utf-8"?>
<Server port="8005" shutdown="SHUTDOWN">
<Listener className="org.apache.catalina.startup.VersionLoggerListener" />
<Listener className="org.apache.catalina.core.AprLifecycleListener" SSLEngine="on" />
<Listener className="org.apache.catalina.core.JreMemoryLeakPreventionListener" />
<Listener className="org.apache.catalina.mbeans.GlobalResourcesLifecycleListener" />
<Listener className="org.apache.catalina.core.ThreadLocalLeakPreventionListener" />
<Service name="Catalina">
<Connector port="8090"
maxThreads="150"
protocol="HTTP/1.1"
proxyName="subb.domain.com"
proxyPort="443"
acceptCount="100"
secure="true"
scheme="https"/>
<Engine name="Catalina" defaultHost="127.0.0.1">
<Host name="127.0.0.1" appBase="webapps" unpackWARs="true" autoDeploy="true">
<Context path="" docBase="${catalina.home}/atlassian-jira" reloadable="false" useHttpOnly="true">
<Resource name="UserTransaction" auth="Container" type="javax.transaction.UserTransaction"
factory="org.objectweb.jotm.UserTransactionFactory" jotm.timeout="60"/>
<Manager pathname=""/>
</Context>
</Host>
<Valve className="org.apache.catalina.valves.AccessLogValve" resolveHosts="false"
pattern="%a %{jira.request.id}r %{jira.request.username}r %t "%m %U%q %H" %s %b %D "%{Referer}i"$
</Engine>
</Service>
</Server>
Can someone please help me out? THNX
After some fixes the current situation is:
- Jira and Confluence won't start at the same time. After Jira is started I can restart confluence.
- When using confluence while for instance adding add-ons. It keeps giving proxy errors 443.
Anny clue?
Think about running either Jira or Confluence on the real IP of the host. Running both on one machine is possible but really not recommended. This is the first time I've seen a config running both of them on 127.0.0.1
Try switching one to another IP & check again.
I've tried switching confluence to 127.0.0.2 no results.
Still 502 on port 433.
Check your Confluence server.xml
proxyPort="8443"
Best
JP
Hi JP,
THNX adjusted it in the question and in the code/file. Still getting a service unavailable message. apache port 443.
any clue?
Hm,
maybe:
defaultHost="localhost"
should be changed to 127.0.0.1
Just an idea. Sometimes on Linux localhost uses the loopback device which is not the same as 127.0.0.1
Best
JP
THNX! again changed is it in the question and in the server.xml file. Now confluence works. Funny thing is that Jira stopped working :-).
