Confluence create space problem
Csaba_Kovari July 4, 2018
I have a linked Jira and a Conf server.
I have not been able to create spaces for Confluence for a few days. No error message, nothing happens when I click on the spaces menu.
There's somebody's idea why it does not work?
System info:
Confluence Version5.10.7
Build Number6441
JIRA Software 7.2.3
Regards
Csaba
Csaba_Kovari October 2, 2019
MySQL driver was not correct. For Confluence version 5.10 i had to install the MySQL Connector Java 5.1.30 driver.
jswazzer October 2, 2019
Thanks, I will check into that.
jswazzer October 1, 2019
I'm experiencing the same issues, i click on spaces and it does nothing, when i click on the 3 dots next to create it brings up a pop-up window but just spins and does nothing.
Vickey Palzor Lepcha
July 4, 2018
Do you see your list of Spaces ? Try going to your list of ALL SPACES
July 4, 2018
So when you click on CREATE SPACE nothing happens ?
Yes. If i click to the Space menu or the or add personal space nothing happens.
I think there is no problem with the permissions.
July 4, 2018
Check your global permissions detail and see if you are a member of a group that is allowed to create a space.
July 4, 2018
The group that your user id belongs to - does it have the required permissions ?
