Confluence / jira application links not working on SSL
Andy Preston
We have recently migrated our tomcat based applications to SSL
Confluence & Bamboo have no problem with application links but Jira & Stash are no longer able to link to the SSL applications.
On the applications links pages we get the message:
Application 'Confluence' seems to be offline. Click here to Relocate.
Application 'Jira' seems to be offline. Click here to Relocate.
These applications are able to do user verification through the Jira user directory over SSL and that works fine.
All aplications work fine over SSL in web browsers
We've imported a wildcard/chain certificate into the individual Unix users .keystore and into the trust keystore
We've configured tomcat via server.xml and web.xml to accept connections on their old non-SSL ports but to redirect to the new HTTPS/SSL ports.
The applications have had their base URL changed to reflect their use of HTTPS & the new ports.
Any suggestions and ideas would be greatly appreciated and any additional config details can be provided on request.
5 votes
Andy Preston
Thanks Henning... yes I did do that. In the end, I went for what turned out to be a much simpler option... and used Apache as a reverse proxy.
Henning Tietgens
September 23, 2013
Maybe we should consider this, too. Is there a documantation in the web for this? Or maybe, are you willing to share your configuration?
Henning
Henning Tietgens
September 23, 2013
Andy Preston
No... I didn't use AJP.
There was some documentation somewhere on confluence.atlassian.com that I used to get me started.
But one of the things that made me abandon working with Tomcat & do an Apache reverse proxy is I've done a lot of Apache config anyway (My main job is as a PHP developer) so I just used my experience.
I'll see if I can post my config soon.
Andy Preston
Apache Config:
LoadModule rewrite_module modules/mod_rewrite.so
Listen 8080
NameVirtualHost *:8080
# We've got a mod_rewrite on port 8080 to redirect all our old links
# to the SSL port
<VirtualHost *:8080>
  ServerName example.example.com
  ServerAlias example
  RewriteEngine On
  RewriteRule ^(.*)$ https://example.example.com/$1 [QSA,R=301,L]
</VirtualHost>
# Jira's "official" port is 8080 but the proxy is using 8081
# See notes above for URL redirection for an explanation of this
LoadModule ssl_module modules/mod_ssl.so
Listen 443
NameVirtualHost *:443
<VirtualHost *:443>
  ServerAlias example
  RewriteEngine on
  RewriteCond %{HTTP_HOST} ^example$
  RewriteRule (.*) https://example.example.com/$1 [QSA,R=301,L]
  ProxyRequests Off
  <Proxy *>
    Order deny,allow
    Allow from all
  </Proxy>
  ProxyPass / http://example.example.com:8081/
  ProxyPassReverse / http://example.example.com:8081/
  SSLEngine on
  SSLProxyEngine on
  RequestHeader set Front-End-Https "On"
  BrowserMatch "MSIE [2-6]" nokeepalive ssl-unclean-shutdown downgrade-1.0 force-response-1.0
  BrowserMatch "MSIE [17-9]" ssl-unclean-shutdown
  SSLCertificateFile /etc/ssl/certs/example.example.com.pem
  SSLCertificateKeyFile /etc/ssl/certs/example.example.com.key
  SSLCertificateChainFile /etc/ssl/certs/chain.cer
</VirtualHost>
Andy Preston
Jira server.xml Connector spec:
<Connector
  port="8081"
  maxThreads="150"
  minSpareThreads="25"
  connectionTimeout="20000"
  enableLookups="false"
  maxHttpHeaderSize="8192"
  protocol="HTTP/1.1"
  useBodyEncodingForURI="true"
  scheme="https"
  proxyName="example.example.com"
  proxyPort="443"
  redirectPort="8443"
  acceptCount="100"
  disableUploadTimeout="true"
Andy Preston
Jira server.conf "Connector" spec:
<Connector
  port="8081"
  maxThreads="150"
  protocol="HTTP/1.1"
  scheme="https"
  proxyName="buster.mathembedded.com"
  proxyPort="443"
  redirectPort="8443"
  acceptCount="100"
Henning Tietgens
September 17, 2013
Did you import the key chain of the other server into the Java keystore (cacerts) of the application? After that you have to restart the application.
