I'm using this jira issue creation code and i'm trying to add multiple labels. This code keeps throwing an error. It's the label entry that is giving the problem. Highlighted below.
"fields": {
"project": { "key" : "[entry.JiraProjectKey]" },
"issuetype" : { "name": "Request" },
"summary" : "[entry.Summary]",
"labels" : "[entry.lob.asArrayOfKVPairs(name)]",
"description" : "[entry.details]",
"customfield_18600" : "[entry.RequestorName]",
"customfield_12704" : "[entry.RequestorEmail]",
"customfield_18608" : "[entry.Businesscontact]",
"customfield_18612" : "[entry.system]",
"customfield_20026" : "[entry.GroupsImpacted]"
Try the following
"labels": [[entry.lob.asArray]],
Hi @Anthony Rita ,
I haven't worked that much with ConfiForms, so I guess the best bet, if no one answers here, would be to reach out to the vendor - Ventuna directly: ConfiForms - Data Forms & Workflows for Confluence / Support
Vendors are usually quite helpful regarding troubleshooting or use case questions that end users have.
Tobi
