Connect gitlab repo to existing jira project
Eldar
June 2, 2022
Hi! is there is a way to add new gitlab repo to already created jira project?
Thanks! eldar.
2 accepted
Anna Odrynska - Alpha Serve
Hi @Eldar
Welcome to the Community!
You can also take a look at our app - Smart Git Integration for Jira.
With it you will be able to add the needed gitlab repository (or few of them) to the existing project in Jira.
Anna
Fabio Racobaldo _Catworkx_
Hi @Eldar ,
welcome to the Atlassian community!
Please cread this article https://docs.gitlab.com/ee/integration/jira/ that explains hoe to integrate gitlab with JIRA.
Moreover, there are some apps on the marketplace like the following https://marketplace.atlassian.com/apps/4984/git-integration-for-jira?tab=overview&hosting=cloud
Hope this helps,
Fabio
