Connecting Bamboo/Jira/Stash
Ralf Gürsoy May 13, 2014
i ve setup bamboo/jira/stash and confluence on an ec2 instance. Now i want to link these applications, but it doesnt work.
Ive added stash to bamboo, stash is marked as primary, but above is a message which states that stash seems to be offline.
Another error is, that if i try to link jira to bamboo an error appears which states that it cant link to itself since it has the same id.
Also i do not know where to get the consumer key or service provide.
Thanks in advance
Radek Antoniuk
November 19, 2014
If you are talking about an OnDemand instances, then try to contact support, they should be able to help you out.
