Connecting to External MS SQL Database from JIRA using Groovy SQL
Jan Sękara May 10, 2017
I'm trying to display  information on issue, based on customfield value.
Example:
Customfield XXXX has value "4"
I want to select external database table (Columns: X,Y)for a row(s) Y when row X = 4
I tried to use Database Custom Field 4.0 but failed (no such possibility)
So...maybe by groovy?
But how do I connect to external database (SQL) assuming that I already have drivers (DCF 4.0 works with selecting but i can see data only while editing).
Can anyone help with this issue?
I've found some information on the web, but nothing worked yet :/
Chander Inguva
May 11, 2017
Hey Jan,
Not sure, how much this helps, but i do have a sql query that gives me custom field values on a jira issue
select cfv.STRINGVALUE,ji.issuenum,p.pkey from customfieldvalue cfv
JOIN customfield cf ON
cf.ID = cfv.CUSTOMFIELD
JOIN jiraissue ji ON cfv.ISSUE = ji.ID
JOIN project p ON ji.PROJECT = P.ID
WHERE cfv.ISSUE IN (select ji.ID from jiraissue ji where PROJECT = 14701) AND cfv.CUSTOMFIELD = 14611 AND cfv.STRINGVALUE IS NOT NULL ORDER BY ji.issuenum ASC
Jan Sękara May 11, 2017
OK i have a script, but printing does not work properly. It sends a query to SQL but nothing is displayed.
Seccond thing, how to put value from customfield to SQL query?
import groovy.sql.Sql
import java.sql.Driver
def driver = Class.forName('com.microsoft.sqlserver.jdbc.SQLServerDriver').newInstance() as Driver
def props = new Properties()
props.setProperty("user", "jira")
props.setProperty("password", "xxxxxxxxxxxxxx")
def conn = driver.connect("jdbc:sqlserver://srv-erp.office.xxxxxxxxxxx.com:1433;DatabaseName=xxxxxxxxxxxxxxxxxxxxx", props)
def sql = new Sql(conn)
try {
sql.eachRow("SELECT * from table") {
log.debug(it)
println "Hello world!"
} finally {
sql.close()
conn.close()
Chander Inguva
May 10, 2017
Did you try this ?
import java.sql.*;
class Example {
   static void main(String[] args) {
      // Creating a connection to the database
      def sql = Sql.newInstance('jdbc:jtds:sqlserver://localhost:1433/atlstatus', 'sa',
         'xxxxxxxx', 'net.sourceforge.jtds.jdbc.Driver')
      sql.eachRow('select * from Status') {
         tp ->
         println([tp.ID,tp.APPLICATION,tp.INCIDENTDATE])
      sql.close()
Hope this gets you started.
Cheers
Chander
Chandler thanks, but.. .i did it like below and result is null...
import java.sql.*;
class Example {
def sql = Sql.newInstance('jdbc:sqlserver://srv-erp.office.xxxxxxxx.com:1433', 'jira',
'xxxxxx', 'com.microsoft.sqlserver.jdbc.SQLServerDriver')
sql.eachRow('SELECT * FROM KntKonta') {
tp ->
println(tp.KKT_OKRESID, tp.KKT_KKSNUMER)
sql.close()
 I get errors:
