Connecting to external JIRA boards for Project Management
christacap
July 30, 2020
Is there a way to connect to receive and send updates to an external party's JIRA board?
Andriy Dekhtyar [Rozdoum]
Hi @christacap
Based on the context - what do you mean with external party's Jira board.
If you tempt to refer to external Jira then your choice would be either
- synchronization of projects, as Stephen mentioned or
- solution Watchtower for Jira that can consolidate data from multiple Jira's into one Agile board.
Regards
Andrey from Watchtower team
Ste Wright
Hi @christacap
You can link two Jira Instances together - see more details on this page about Using AppLinks
Or for more specific control over which projects / issues communicate, you'd need to consider an app such as Backbone Issue Sync
If neither of these were what you were looking to achieve, give us some more specifics so we can advise further :)
Ste
