×Hi!
I have faced with this problem on production server. JIRA becomes unavailable.
Query
select * from pg_stat_activity
returns only one connection.
PostgreSQL 9.2 and JIRA 5.0.4 run on the same server.
My dbconfig:
<jira-database-config> <name>defaultDS</name> <delegator-name>default</delegator-name> <database-type>postgres72</database-type> <schema-name>public</schema-name> <jdbc-datasource> <url>jdbc:postgresql://localhost:5432/jiradb</url> <driver-class>org.postgresql.Driver</driver-class> <username>***</username> <password>***</password> <pool-size>50</pool-size> <validation-query>select version();</validation-query> <validation-query-timeout>2</validation-query-timeout> <min-evictable-idle-time-millis>10000</min-evictable-idle-time-millis> <time-between-eviction-runs-millis>50000</time-between-eviction-runs-millis> <pool-max-idle>20</pool-max-idle> <pool-remove-abandoned>true</pool-remove-abandoned> <pool-remove-abandoned-timeout>50</pool-remove-abandoned-timeout> <pool-test-while-idle>true</pool-test-while-idle> <pool-prepared-statements>true</pool-prepared-statements> </jdbc-datasource> </jira-database-config>
There are no exceptions in log file concerned with connection pool.
What is the problem?
I need to decrease some parameter?
Well, I have found in GC log concurrent mode failure. Also found that at the time the xml-backup service worked.
I turned off this service, as recommended here https://confluence.atlassian.com/display/JIRA/Automating+JIRA+Backups
I will look further.
If there are no exceptions in the log, why do you think it's a connection pool error?
What does the log file actually say is wrong when "Jira becomes unavailable"? Have you looked at all the resources on the system? CPU, memory etc? You need to try to establish what the error really is, not just assume it's a database problem.
Hi Dimitri,
Like Nic says: take a look in the JIRA log files.
Because the one connection that your query is returning is the connection you are using to execute that query. So it seems to me that there is already a problem before JIRA even tries to connect to the database.
Best regards,
Peter
No Peter. I have one connection except that I have used to run the query.
Thanks for your answer, Nic!
You are right I don't know a real cause. I started with DB problem because it is that i see.
I can't find any appropriate exceptions, just
2014-06-24 10:42:30,711 http-8090-105 ERROR username 640x34291x15 ks7xg5 100.112.6.126 /secure/QuickCreateIssue.jspa [jira.issue.index.DefaultIndexManager] Wait attempt timed out - waited 30000 milliseconds com.atlassian.jira.issue.index.IndexException: Wait attempt timed out - waited 30000 milliseconds
or
2014-06-24 12:28:54,810 http-8090-97 ERROR anotherusername 748x22138x146 16udnqy 100.112.6.157 /secure/Dashboard.jspa [renderer.internal.http.HttpClientFetcher] Unable to retrieve response org.apache.http.conn.ConnectTimeoutException: Connect to myjira/127.0.0.1:8090 timed out
I have low CPU usage, less than 10% even when JIRA unavailable.
I can't access secure/admin/ViewMemoryInfo.jspa at problem time. At the other time i see something like this
I will enable GC log also.
Maybe there is a memory problem, how to check it?
