I have a docker cluster running jira, but I can't seem to get the gadget URL to pass.
I have the base URL set to "jira.xxx"
My docker compose file looks like
services:
jira:
image: <jira 9.12.22>
container_name: jira
networks:
- jira_network
ports:
- 8070:8070
volumes: ...
extra_hosts:
- "jira.xxx:<host server IP>"
nginx-proxy:
image: nginx:latest
container_name: nginx-proxy
networks:
- jira_network
ports:
- 80:80
- 443:443
volumes: ...
depends_on:
- jira
networks
jira_network:
driver: bridge
My nginx proxy is standard with
server{
listen 443 ssl;
server_name jira.xxx
ssl stuff
location / {
proxy_pass http://jira:8070;
proxy_set_header Host $host;
proxy_set_header ... (x real ip, x forwarded for, x forwarded proto
server {
listen 80;
server_name jira.xxx;
return 301 https://$host$request_uri;
The server works perfectly for everything but the gadget. If I remote into the jira container and attempt a "curl -v jira.xxx" then I can see that it hits the host IP as expected, but then the connection times out. Any ideas?
I asked chat GPT, here is what it suggested:
It sounds like your nginx proxy might be hitting a timeout or buffering issue when Jira gadgets are loaded.
Here are a few things to check in your nginx configuration:
✅ Increase proxy timeout values → Add or adjust these settings in your nginx config:
proxy_read_timeout 300; proxy_connect_timeout 300; proxy_send_timeout 300;
✅ Increase buffer sizes → Sometimes gadgets fail due to insufficient buffer:
proxy_buffers 16 64k;
proxy_buffer_size 128k;
✅ Check max body size (if POST requests are failing)
client_max_body_size 10m;
✅ Pass correct headers → Ensure you’re passing these to avoid breaking the gadgets:
proxy_set_header X-Forwarded-Host $host;
proxy_set_header X-Forwarded-Server $host;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
✅ Jira base URL → Make sure Jira’s base URL (in Jira system settings) matches the public URL behind nginx.
If you apply these and still hit timeouts, check:
Jira server logs (atlassian-jira.log
nginx error logs
