Control Access to Applicaitons by Project
Bosa IT
February 4, 2020
We have several plug ins that are not needed in many of the Jira Projects we have set up. Can i hide or configure the apps to only be used by certain projects?
Tony Rossiter
February 4, 2020
@Bosa IT
I varies from add-on to add-on.  Some come with the ability to include/exclude projects.  Others are available system wide.  I’d look at each and determine if you can do this and, if not, make a determination whether you still need it or not.
